Showing payments lines on PDF
Is there a variable to display invoice payments? If not, which file do I have to edit ?
I’m currently looking at ressources\assets\js\pdf.pdfmake.js but it looks like my changes doesn’t affect the PDF rendering…
Best regards,
Dylan
It isn’t supported in the app.
If you make changes to the code you need to use gulp to recompile the built files, there’s some info here:
https://docs.invoiceninja.com/developer_guide.html#code
Thanks you for your quick answer,
I wasn’t aware of js files being compiled.
Because some people could be lost, as I was, trying to fix gulp v^3.9 (which is not compatible with node v^12), there is are some posts that helped me :
Thanks and have a nice day !
