Hi!
I recently installed invoiceninja on my ubuntu VPS using apache, I havent used the docker version. I can navigate to /setup fine and run the setup but it just reloads the 1st page after ive completed it. If i go to billing.domain.co.uk i get error 500. Attached is my laravel.log, if any other logs are needed comment and ill send them as im not sure what else may be needed!
Hey there, thanks for reporting this. Iâll need you to be more explicit.
After you complete the setup, you should be redirected to login page.
Maybe you can turn on debugging mode & see whatâs wrong:
Edit .env file (in Invoice Ninja folder)
Edit APP_DEBUG=true
Run: php artisan optimize
Now you should be able to see the erorr. Donât forget to set it to false & optimize again, as this debug mode can expose some private info to public. Thanks
Hi!
Dont it and it says âSQLSTATE[42S02]: Base table or view not found: 1146 Table âninja.accountsâ doesnât exist (SQL: select * from accounts limit 1)â
But im not sure why its doing this? its just a blank database, shouldnt the setup add all the tables etc? That errors from going to the domain itself. I also dont get a login page, the setup just repeats, if i forcibly go to https://billing.domain.co.uk i get error 500
I try to migrate/install v5 since yesterday and have some weird issues. v4 was easy to install, but I have no idea what is going on here. But, I am here to help as good as possible, as I really like invoiceninja.
(sorry I couldnât reproduce the 500 error from yesterday, as I wasnât able to post more as a new member here)
