I’ve been using 4.5 for a while, just began installing v5 to test.
Problem is that after filling out all info on the setup page (and verifying it) I click submit and am redirected to the setup page.
I checked in my server root and the .env file is not created. I also tried creating my own .env from the example (and filling out all relevant details), but I am still stuck at the setup page.
I have to admit that I am new to v5 so I don’t know yet where to look for problems. I checked permissions on the folder and they are all owned by www-data:www-data.
Nginx, Debian 10, PHP 7.4
Please help me figure out where to look for the problem.
Ensure the file permission have been set to the web server user. For example in Ubuntu this is www-data if you have configured a virtual host with a root directory of /var/www/html you would set the ownership like this.
Yes thank you for the suggestion, I have tried setting the ownership a few times already.
I tried setting the permissions again on Invoice Ninja’s root folder (the html folder for nginx) using the exact command above, and I am still redirected back to the setup page. I checked to make sure that nginx is running as www-data and it is.
For some reason the .env is not working, or there is some other problem I haven’t thought of.
Hi again, I have fixed it so far, thanks to your help.
I tried two things at the same time, I’m not sure which one worked:
php artisan migrate:fresh --seed
from the guide, as well as:
kind of embarrassing, but it is possible that my password manager had been replacing my database credentials when I entered my user credentials in the lower pane. If this is what fixed it it counts as human error so I’m going to say that the previous fix worked.
