I’m trying to setup a development environment, but the documentation on how to do it is basically non-existant. The developer guide only says the following about it:
The zip includes all third party libraries, whereas checking out the code from GitHub requires using Composer.We use Gulp to concatenate the JavasScript and CSS files. You can download the source files with Bower. After making any changes you need to run gulp to re-generate the built files.
And that’s it. Maybe for an experienced php/laravel developer that explanation is enough, but for someone starting at this is well, is basically useless.
Could someone explain a little further how to setup a local development environment ? I was able to install all the dependencies using composer, but when running bower install I get this error:
$ bower install
bower EMALFORMED Failed to read /home/juancho/invoiceninja/bower.json
Additional error details:
Unexpected token } in JSON at position 1280
Some more detail on the steps needed to do the dev setup would be great.
Thanks.
