I am trying to setup a cronjob as per this link:
https://invoiceninja.github.io/docs/self-host-installation/#cron-configuration-1
I host with a company called xneelo/hetzner who have their own custom hosting panel called konsoleH, so the syntax is slightly different.
They have provided a link with the correct syntax but I am not getting it right:
Can anyone assist please?
Are you seeing a specific error?
Unfortunately not. Is there a way I can check or test that the cronjob is working?
4
You’ll see an error icon in the lower left corner of the app if the cron isn’t running.
@david is there a way to manually check if the cron is running?
The error icon has disappeared today, so maybe it works, but I am not sure how to check 100%
david
6
@justinwhittaker
if the icon has disappeared, it means the crons are working as expected.
