Set invoice template per client (or based on language/country)?
My goal is to be able to automatically create invoices for my clients in English or German (if their country is set to Germany, I want to use a custom template in German, if they are from another country, I want to use a template in English).
Since I use the API endpoint (/api/v1/invoices) for creating invoices, I’m wondering what is the best way to realize this programmatically, as the endpoint does not have a property for template_id.
Also, the endpoint for creating a client does not allow to set a specific template_id.
I found the option to set an invoice template for a client in the app (using self-hosted docker version) - however, when I set a different template for clients and pre-viewed their pdf invoices, they all still used the same general template, that I’ve set in the general invoice design settings.
Any ideas how to solve this issue?
One option may be to create two groups: English and German, and then assign specific clients to each group.
Thank you very much, @hillel! That - again - works perfect! :slight_smile:
