I am getting this error when sending a purchase order. What I can see is the purchase order table has a mismatched name:
Table on error: ninja_ninj222.purchaseOrders
Table on MyAdmin: ninja_ninj222.purchase_Orders
How do I fix this?
[2024-01-08 12:53:03] production.ERROR: SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘ninja_ninj222.purchaseOrders’ doesn’t exist (Connection: mysql, SQL: select count() as aggregate from purchaseOrders
where id
= 2 and company_id
= 3) {“userId”:1,“exception”:"[object] (Illuminate\Database\QueryException(code: 42S02): SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘ninja_ninj222.purchaseOrders’ doesn’t exist (Connection: mysql, SQL: select count() as aggregate from purchaseOrders
where id
= 2 and company_id
= 3) at /home/vendor/laravel/framework/src/Illuminate/Database/Connection.php:822)
#0 /home/vendor/laravel/framework/src/Illuminate/Database/Connection.php(776): Illuminate\Database\Connection->runQueryCallback(‘select count()…', Array, Object(Closure))
#1 /home/vendor/laravel/framework/src/Illuminate/Database/Connection.php(407): Illuminate\Database\Connection->run('select count()…’, Array, Object(Closure))
#2 /home/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2751): Illuminate\Database\Connection->select(‘select count(*)…’, Array, false)
#3 /home/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2740): Illuminate\Database\Query\Builder->runSelect()
#4 /home/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3294): Illuminate\Database\Query\Builder->Illuminate\Database\Query\{closure}()
#5 /home/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2739): Illuminate\Database\Query\Builder->onceWithColumns(Array, Object(Closure))
#6 /home/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3221): Illuminate\Database\Query\Builder->get(Array)
#7 /home/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3149): Illuminate\Database\Query\Builder->aggregate(‘count’, Array)
#8 /home/vendor/laravel/framework/src/Illuminate/Validation/DatabasePresenceVerifier.php(54): Illuminate\Database\Query\Builder->count()
#9 /home/vendor/laravel/framework/src/Illuminate/Validation/Concerns/ValidatesAttributes.php(903): Illuminate\Validation\DatabasePresenceVerifier->getCount(‘purchaseOrders’, ‘id’, 2, NULL, NULL, Array)
#10 /home/vendor/laravel/framework/src/Illuminate/Validation/Concerns/ValidatesAttributes.php(874): Illuminate\Validation\Validator->getExistCount(NULL, ‘purchaseOrders’, ‘id’, 2, Array)
#11 /home/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(657): Illuminate\Validation\Validator->validateExists(‘entity_id’, 2, Array, Object(Illuminate\Validation\Validator))
#12 /home/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(457): Illuminate\Validation\Validator->validateAttribute(‘entity_id’, ‘Exists’)
#13 /home/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(492): Illuminate\Validation\Validator->passes()
#14 /home/vendor/laravel/framework/src/Illuminate/Validation/ValidatesWhenResolvedTrait.php(31): Illuminate\Validation\Validator->fails()
#15 /home/vendor/laravel/framework/src/Illuminate/Foundation/Providers/FormRequestServiceProvider.php(30): Illuminate\Foundation\Http\FormRequest->validateResolved()
#16 /home/vendor/laravel/framework/src/Illuminate/Container/Container.php(1302): Illuminate\Foundation\Providers\FormRequestServiceProvider->Illuminate\Foundation\Providers\{closure}(Object(App\Http\Requests\Email\SendEmailRequest), Object(Illuminate\Foundation\Application))
#17 /home/vendor/laravel/framework/src/Illuminate/Container/Container.php(1266): Illuminate\Container\Container->fireCallbackArray(Object(App\Http\Requests\Email\SendEmailRequest), Array)
#18 /home/vendor/laravel/framework/src/Illuminate/Container/Container.php(1252): Illuminate\Container\Container->fireAfterResolvingCallbacks(‘App\\Http\\Reques…’, Object(App\Http\Requests\Email\SendEmailRequest))
#19 /home/vendor/laravel/framework/src/Illuminate/Container/Container.php(813): Illuminate\Container\Container->fireResolvingCallbacks(‘App\\Http\\Reques…’, Object(App\Http\Requests\Email\SendEmailRequest))
#20 /home/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(957): Illuminate\Container\Container->resolve(‘App\\Http\\Reques…’, Array, true)
#21 /home/vendor/laravel/framework/src/Illuminate/Container/Container.php(731): Illuminate\Foundation\Application->resolve(‘App\\Http\\Reques…’, Array)
#22 /home/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(942): Illuminate\Container\Container->make(‘App\\Http\\Reques…’, Array)
#23 /home/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(85): Illuminate\Foundation\Application->make(‘App\\Http\\Reques…’)
#24 /home/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(50): Illuminate\Routing\ControllerDispatcher->transformDependency(Object(ReflectionParameter), Array, Object(stdClass))
#25 /home/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(29): Illuminate\Routing\ControllerDispatcher->resolveMethodDependencies(Array, Object(ReflectionMethod))
#26 /home/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(59): Illuminate\Routing\ControllerDispatcher->resolveClassMethodDependencies(Array, Object(App\Http\Controllers\EmailController), ‘send’)
#27 /home/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(40): Illuminate\Routing\ControllerDispatcher->resolveParameters(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\EmailController), ‘send’)
#28 /home/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\EmailController), ‘send’)
#29 /home/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(19): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#30 /home/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch(Object(Closure), Object(Illuminate\Routing\Route))
#31 /home/vendor/laravel/framework/src/Illuminate/Routing/Route.php(259): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\EmailController), ‘send’)
#32 /home/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController()
#33 /home/vendor/laravel/framework/src/Illuminate/Routing/Router.php(806): Illuminate\Routing\Route->run()
#34 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#35 /home/app/Http/Middleware/UserVerified.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#36 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\UserVerified->handle(Object(Illuminate\Http\Request), Object(Closure))
#37 /home/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(122): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#38 /home/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(87): Illuminate\Routing\Middleware\ThrottleRequests->handleRequestUsingNamedLimiter(Object(Illuminate\Http\Request), Object(Closure), ‘api’, Object(Closure))
#39 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\ThrottleRequests->handle(Object(Illuminate\Http\Request), Object(Closure), ‘api’)
#40 /home/app/Http/Middleware/QueryLogging.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#41 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))
#42 /home/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#43 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#44 /home/app/Http/Middleware/Locale.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#45 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Locale->handle(Object(Illuminate\Http\Request), Object(Closure))
#46 /home/app/Http/Middleware/TokenAuth.php(101): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#47 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\TokenAuth->handle(Object(Illuminate\Http\Request), Object(Closure))
#48 /home/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#49 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\SetDb->handle(Object(Illuminate\Http\Request), Object(Closure))
#50 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#51 /home/vendor/laravel/framework/src/Illuminate/Routing/Router.php(805): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#52 /home/vendor/laravel/framework/src/Illuminate/Routing/Router.php(784): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#53 /home/vendor/laravel/framework/src/Illuminate/Routing/Router.php(748): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#54 /home/vendor/laravel/framework/src/Illuminate/Routing/Router.php(737): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#55 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(200): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#56 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#57 /home/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#58 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestIpMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#59 /home/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#60 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#61 /home/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#62 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Livewire\Features\SupportDisablingBackButtonCache\DisableBackButtonCacheMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#63 /home/app/Http/Middleware/Cors.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#64 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Cors->handle(Object(Illuminate\Http\Request), Object(Closure))
#65 /home/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#66 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#67 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#68 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#69 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#70 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#71 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#72 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#73 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#74 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#75 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(99): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#76 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#77 /home/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(87): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#78 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Tracing\Middleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#79 /home/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#80 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(175): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#81 /home/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(144): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#82 /home/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#83 {main}
