Separate SMTP e-mail for each in Mutli-Company
Good day,
I’ve setup 2 companies (each have their own accounts@ mailbox).
In Invoice Ninja v5, however, in the .env file we only have the option to use one “MAIL_FROM_ADDRESS”
Is there a way for each company in a Multi-company setup to use their own mailbox settings?
Thanks in advance.
I don’t believe this is supported yet.
cc @david in case I’m wrong…
Same problem here. If you want a temporary/hacky workaround until the devs add this functionality, and you have the same mail server hosting the different domains, the following has worked for us:
I’ve changed the following line of code in app/Mail/TemplateEmail.php:
(Line 81)
$this->from(config(‘mail.from.address’), $this->company->present()->name());
To:
$this->from($settings->reply_to_email,$settings->reply_to_name);
This sends our invoices from the reply-to email and reply-to name under Settings > Email Settings.
Again, only works because our SMTP credentials (username and password) are the same for the different domains we use. Also only tested on sending invoices - there may be other references in other files for different emails the system sends out.
Thank you so much! Will give that a go :slight_smile:
Just to update, this is now supporter as per this thread
I was unable to get this to work. It seems to only use “MAIL_USERNAME=” when I removed it and used “1_MAIL_USERNAME=” it just defaulted to [email protected]
What am I missing?
php artisan config:cache
php artisan config:clear
Can you confirm you have ran this command?
Also, are you definitely seeing a problem with the MAIL_USERNAME field? or the MAIL_FROM_ADDRESS field?
Yea, sorry I meant the MAIL_FROM_ADDRESS field.
I ran both commands in succession but it doesn’t seem to work for me.
In the next release, we’ll also support the FROM_ADDRESS and FROM_NAME env variables to be per company also.
I upgraded to 5.5.40
I also manually deleted to config cache file from /bootstrap/cache
It is working as it should now, Thanks!
