How is it possible to send invoice reminders via API.
Havent found endpoints related to reminders in the specification.
Please, advise.
Regards, AK
Please, advise.
Regards, AK
I believe when using the /email route you can set template to reminder1 to manually send the reminder.
curl --request POST \
--url 'https://invoicing.co/api/v1/emails?=' \
--data '{
"entity": "invoice",
"entity_id": "xbo2J2V3ag",
"template": "reminder1",
"body": " ",
"subject": "Test subject"
when I use above data I get error:
"message": "The given data was invalid.",
"errors": {
"template": [
"The template field is required."
Try adding: -H "Content-Type:application/json"
Thank you @hillel
No, the issue was incorrect template name “reminder1”
Here I’ve found correct namings and for the reminder 1 I had to use “email_template_reminder1”
Not it works.
Glad to hear it’s working, thanks for sharing the solution!
