is there an option to send all emails to the same address. Or use the “from” address as the “to” address? This is for testing purposes only. I couldn’t find anything in the UI but maybe there is a file that I can change.
I want to migrate another billing software to InvoiceNinja and want to test things to make sure, everything is working as planned. But I don’t want to send emails to customers during this test phase.
Maybe there is a quick solution for this.
Many thanks in advance!
Gijs
March 2, 2023, 2:55pm
#2
One option may be to set the mail driver to log
, this will write all emails to the log file rather than send them.
Hi @hillel
that would be a perfect solution. I don’t see this option in the settings. I tried to set
MAIL_MAILER=log
in the env file and recreated the docker container. But then the email was still received. Do I need to run some php artisan command?
Thanks a lot
Gijs
March 2, 2023, 3:31pm
#4
It may help to load /update?secret= to update the cached config.
Note: you can check which driver is being used in the health check in the app.
Hmm, unfortunately /update?secret=xxxxx
did not change anything.
The health check still says smtp and emails are still sent. I also tried
docker exec -it [container] php artisan optimize
but that didn’t work either
Any other idea?
March 2, 2023, 3:58pm
#6
@david can you please advise?
david
March 2, 2023, 10:27pm
#7
@ecomsilio
Assuming you are using our standard docker-compose file you should only need to edit the env file in the root of the dockerfiles directory
I just tested this by taking down the container, changing the MAIL_MAILER to log and then bringing up the container again.
Also just ensure your env doesn’t have the MAIL_MAILER in there twice a bit further down.
Sorry, this is awkward. It all works as long as I make the change to the correct env File
