I had an issue where I lost my 2fa token and to reset the mysql db I had to revert back to a v4 build… I don’t recall why, but the reset options weren’t working when I was updated to v5.
I rolled back system to a snapshot to my last v4 saved. At this point i was able to reset the 2fa. Then I forgot about it and it had since auto purged old snapshots, old being the v5 snapshots. Now I’m having an issue updating to v4.5.50 to run the upgrade process. When I extract the ninja-v4.5.50.zip file over my /var/www/html/invoiceninja it appears to work, I reboot. and log in and it’s still 4.5.14.
Kind of scratching my head here.
Seems like a bad time to learn docker as in theory it seems like it would be easier to just deploy a 4.5.50 container to import my info and do an export for v5, but again I don’t know docker.
I’ve already spun up a v5 system on Digital Ocean to import, and then spit out a v5 backup for a final deployment back on v5.
Long short, any suggestion for getting around not being able to upgrade my current 4.5.14 system to 4.5.50?
