Selfhosted and cloudflare
Hello all,
I’m trying to install a docker composer istance of IN on a server and then I would like to expose it to the web using the cloudflared
Could someone help me to understand how should I config the config/host and the env file?
Sorry, I don’t have an example to provide.
Don’t worry, maybe someone else will :wink:
I suggest you find some other similar service that has setup instructions for your case and follow them.
there are plenty of examples of docker-compose.yml around here if you need those.
