Hi all!
I installed InvoiceNinja on a subdomain, without setting SSL.
So, my root is /var/www/domain.com/html/ninja/public and can be accessed by http://ninja.domain.com
The root is set as such in the file located at /etc/NGINX/sites-available/domain.com
I’m using Debian, NGINX, PHP7.0-FPM and MariaDB.
My problem is that everytime I want to reach http://ninja.domain.com (or if I browse http://ninja.domain.com/index.php ), it rewrite the adress bar to show http://ninja.domain.com/setup (or http://ninja.domain.com/index.php/setup ) which result in an error 404 page not found.
Is there any guru here that could help me or point what I should look into? I think I’m close to make it work but needs to get over that issue.
Thanks!
February 5, 2018, 8:01am
If you’re seeing index.php in the URL it usually means mod rewrite needs to be enabled.
I’m not seeing it unless I specifically put it in the address bar.
If i browse http://ninja.domain.com the address bar get changed to http://ninja.domain.com/setup and it returns error 404.
Thanks for helping me!
Thanks Hillel,
by insisting on mod_rewrite, you had me understand that NGINX doesn’t follow .htaccess. I had to add
" try_files $uri $uri/ /index.php?$args; "
in the domain.com config file under server ninja.domain.com location.
robink
April 15, 2019, 2:03pm
6
Guys, your posts made my monday, finally got to get to the invoice ninja install screen… pfew ! and thanks to that last comment of kebel87 where he mentions Hillel insistence…
Well Hillel, you’ve just shot two birds with one stone… (solved at 6am), but still
Much appreciated guys
