Hi guys,
Please forgive me for not having the version numbers as I did not write them down and I am unable to see what they are. I do recall there being a version file somewhere but I can’t seem to find it.
All I did was logged into my invoiceninja portal as my admin user, I saw the little orange triangle in the bottom left and I clicked it, it showed the current version and the version it was upgrading to and I did not take note of them as I have never had any issues before. This is with version 5 of invoice ninja. Below I have provided the web server error.log for this issue. When I try to load the site, I get a 500 error saying this page is not working however, the error does not match any of the error conditions I have seen on the troubleshooting page. Can someone please advise me on how I might go about fixing this without losing any data in the database as this would severely screw up my accounting?
I am currently running PHP 7.4.3 , I do believe many servers are deprecating this version of PHP, is this the case here? Should I upgrade to version 8.x?
Thank you!
Systops
Here are the entries in the log file: /var/log/nginx/ininja.error.log
root@portal:/etc# tail /var/log/nginx/ininja.error.log
#4 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(112): Illuminate\Foundation\Http\Kernel->reportException()
#5 /usr/share/nginx/invoiceninja/public/index.php(57): Illuminate\Found" while reading response header from upstream, client: 192.241.xxx.xxx, server: portal.systopiansolutions.com, request: “GET /actuator/health HTTP/1.1”, upstream: “fastcgi://unix:/run/php/php-fpm.sock:”, host: “207.xxx.xxx.xxxx”
2022/11/09 14:49:12 [error] 1729197#1729197: *55137 FastCGI sent in stderr: “PHP message: PHP Notice: Trying to access array offset on value of type null in /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php on line 45PHP message: PHP Fatal error: Uncaught Error: Call to a member function connection() on null in /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php:45
Stack trace:
#0 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(166): Illuminate\Support\Facades\Schema::getFacadeAccessor()
#1 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(255): Illuminate\Support\Facades\Facade::getFacadeRoot()
#2 /usr/share/nginx/invoiceninja/app/Exceptions/Handler.php(80): Illuminate\Support\Facades\Facade::__callStatic()
#3 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(404): App\Exceptions\Handler->report()
#5 /usr/share/nginx/invoiceninja/public/index.php(57): Illuminate\Found” while reading response header from upstream, client: 157.xxx.xxx.xxx, server: portal.systopiansolutions.com, request: “GET / HTTP/1.1”, upstream: “fastcgi://unix:/run/php/php-fpm.sock:”, host: “portal.systopiansolutions.com”, referrer: “http://207.xxx.xxx.xxx/”
Ffor my security I have xxx out the IP addresses.
