I’m facing issue with PDF test during installation.
I get this error message when hit Test PDF button: Oops, looks like something isn’t correct!
Any solution ?
Any solution ?
Which PDF generator are you using?
I set hosted_ninja in .env
Are there any related errors in storage/logs?
[2024-03-11 19:42:33] production.INFO: db fails
[2024-03-11 20:23:03] production.INFO: db fails
[2024-03-11 20:23:07] production.INFO: db fails
[2024-03-11 22:49:57] production.INFO: db fails
[2024-03-11 22:49:59] production.INFO: db fails
[2024-03-12 06:15:09] production.INFO: db fails
[2024-03-12 06:15:25] production.INFO: db fails
[2024-03-12 06:16:30] production.INFO: db fails
[2024-03-12 06:20:51] production.INFO: db fails
[2024-03-12 06:21:11] production.INFO: db fails
[2024-03-12 06:28:28] production.INFO: db fails
[2024-03-12 07:40:43] production.INFO: db fails
[2024-03-12 07:40:45] production.INFO: db fails
[2024-03-12 07:40:48] production.INFO: db fails
Do you see more of the ‘db fails’ errors appear when clicking Test PDF?
no, nothing more apprears
Are you able to complete the setup?
No, I’m still getting the same error when clicking Test PDF.
I don’t know why
Is there an option to complete the setup without the PDF working?
That’s what I want to know.
How to install without pdf test
I’m trying to send you my invoiceninja setup Url to your private message but it seems you don’t accept message
Sorry, I’m not able to debug your installation for you.
Check your browser console. my guess is that your APP_URL is not configured correctly.
I suggest checking that the APP_URL is using https
If you’re using a reverse proxy try adding this to the .env file
TRUSTED_PROXIES=‘*’
It works now, thank you
