Hi All, I am using Invoice Ninja v4.5.19 self-hosted on Ubuntu 16.04 and Nginx. I am trying to set up a ZAP so our cart system can automatically create an invoice. Some of our customers request a branded invoice and our cart system doesn’t do that well.
I am trying to do a Zapier integration and cannot get past the URL verification. The API key is created, but I have tried every permutation of the URL I can find and I always get the same response.
There is no /api/v1 directory, so I read elsewhere on this forum to use mydomain.com/public/api/v1 . No luck. This is what I get every time:
We hit an error adding your new account
authentication failed: Got 404 calling GET https://payments.mydomain.com/public/api/v2/ping?v2=true , expected 2xx.
Make sure you click “Allow” or “Accept” on the permission popup
Double check your Account has the correct permissions
Check out our [help]for more information
The suggested solutions do not make any sense at all. /public permissions are all 644 and the owner is www-data. I am at a total loss.
Does anyone have an idea of what to try? Thanks!
January 5, 2021, 9:47pm
‘api/v1’ (like most routes in the app) is virtual, you won’t see matching files/folders.
You may not need to add ‘/public’ to the URL, you need to add api/v1 to your base app URL.
Thanks, I has seen the virtual routes in there and suspected this.
I forgot to add when I do it with /api/v1 - I get this:
authentication failed: Got 500 calling GET https://payments.mydomain.com/api/v1/ping?v2=true , expected 2xx.
Now if I enter https://payments.mydomain.com/api/v1/ping?v2 in the address bar in the browser, I get “success”, presumably with a 200 response.
So, still no success and I have spent most of the day on it.
January 5, 2021, 10:57pm
4
If you see a 500 error there will be more details in storage/logs/laravel-error.log
Ok, I see this, but I have no idea what email it is trying to get.:
[2021-01-05 22:55:02] production.ERROR: ErrorException [0] : /var/www/invoice-ninja/app/Http/Controllers/AccountApiController.php [Line 43] => Trying to get property ‘email’ of non-object {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:"",“method”:“GET”,“user_agent”:“Zapier”,“locale”:“en”,“ip”:“3.233.219.46”,“count”:1,“is_console”:“no”,“is_api”:“no”,“db_server”:“mysql”,“url”:“api/v1/ping”} []
The line this refers to is…
public function ping(Request $request)
$headers = Utils::getApiHeaders();
// Legacy support for Zapier
if (request()->v2) {
return $this->response(auth()->user()->email); <<----
} else {
return Response::make(RESULT_SUCCESS, 200, $headers);
January 5, 2021, 11:21pm
7
I think you’d see that error if you call the route without including a valid token
Ok, got it. The way the wizard is worded, it sounded like it wanted the token name, not the token. I tried the token and it works fine now.
Thank you for your help!!
