Self Hosted - Add Account
Under my name in the drop down menu, there’s an option for Add Account - I assume this allows me to add an employee account in the system to manage customers and invoicing. However, when I click on this link, it just takes me back to the login screen. I also assume this is not an expected result. Any assistance would be appreciated as I have sales employees that need access as well.
Thanks!
Corey
The option to ‘add an account’ enables you to use the system with multiple separate accounts.
You need to add ALLOW_NEW_ACCOUNTS=true to the .env to enable adding additional accounts on a self host install.
Hi Hillel, so that option allows someone to register and create kind-of a multi-tenant setup in Invoice Ninja where they then manage their own Customers and Invoices. But how can I add another user to my instance so they can manage my clients and invoices? Or is that not possible?
Thanks,
Corey
To add a user under your account click “Add user” on the following page:
/company/advanced_settings/user_management
Excellent - that worked. Thank you!
So is this still possible?
I tried setting ALLOW_NEW_ACCOUNTS=true in the .env on my self host, but I am not sure how I can add a new account?
Best regards
You can add new users via /settings/user_management for your current business
Regards, Sints
Hi, thank you for the reply.
I was wondeirng if it is possible on my self host to add different accounts though, which would be completely separate from each other?
I do not mean multiple users under the same account, but completely different accounts.
(so one ccount wont be able to see information about the other account)
I do not think this is possible (haven’t been using IN for that long) but I think that would be a different business on the same installation?
That is done via: /dashboard?sign_up=true
Sorry, it’s no longer supported. You’d need to setup a separate installation of the app.
