Hello Team, When I send [‘mark_paid’ => true] over the SDK in the invoice details, the invoice is not being marked as paid.
Any ideas?
Regards
I believe the docs are wrong,
instead of mark_paid is should be paid
i’ll correct the docs.
Thank you so much for your fast response!
I just tried and seem to not be working.
Im sending [‘paid’ => true] as second parameter as stated on docs. Also tested mark_paid just in case and didnt work either.
Just in case, Im using Invoice ninja version v5.3.85
Regards
Looking at the code I seen that action is called mark_paid. And I was able to make it work via bulk request, as I seen invoice ninja does at its invoices list.
Example:
$invoiceNinjaId = $ninja->invoices->create( $invoiceDetails )[‘data’][‘id’];
$ninja->invoices->bulk( “mark_paid”, [ $invoiceNinjaId ] );
Regards
