PHP Notice: Trying to access array offset on value of type null in /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php on line 45
PHP Fatal error: Uncaught Error: Call to a member function connection() on null in /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php:45
Stack trace: #0 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(166): Illuminate\Support\Facades\Schema::getFacadeAccessor() #1 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(255): Illuminate\Support\Facades\Facade::getFacadeRoot() #2 /usr/share/nginx/invoiceninja/app/Exceptions/Handler.php(75): Illuminate\Support\Facades\Facade::__callStatic(‘hasTable’, Array) #3 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(366): App\Exceptions\Handler->report(Object(Error)) #4 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(131): Illuminate\Foundation\Console\Kernel->reportException(Object(Error)) #5 /usr/share/nginx/invoiceninja/artisan(37): Illuminate\Found in /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php on line 45
ls -l /usr/share/nginx/invoiceninja/bootstrap/cache/
total 0
cd /usr/share/nginx/invoiceninja/
php artisan tinker
PHP Notice: Trying to access array offset on value of type null in /usr/share/n ginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema .php on line 45
PHP Fatal error: Uncaught Error: Call to a member function connection() on null in /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Suppor t/Facades/Schema.php:45
Stack trace: #0 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support /Facades/Facade.php(166): Illuminate\Support\Facades\Schema::getFacadeAccessor() #1 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support /Facades/Facade.php(255): Illuminate\Support\Facades\Facade::getFacadeRoot() #2 /usr/share/nginx/invoiceninja/app/Exceptions/Handler.php(75): Illuminate\Supp ort\Facades\Facade::__callStatic(‘hasTable’, Array) #3 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundat ion/Console/Kernel.php(366): App\Exceptions\Handler->report(Object(Error)) #4 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundat ion/Console/Kernel.php(131): Illuminate\Foundation\Console\Kernel->reportExcepti on(Object(Error)) #5 /usr/share/nginx/invoiceninja/artisan(37): Illuminate\Found in /usr/share/ngi nx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.p hp on line 45
