Running invoiceninja 5 behind nginx proxy
I am trying to run invoiceninja 5 behind a ningx reverse proxy. With the following set up:
ningx reserver proxy available from outside: https://www.demo.com
nginx webserver on a second server (available only within the LAN) http://invoiceninja.localdomain.com:81
Invoiceninja should be available thru the url https://www.demo.com/ninja/ for the outside.
I had a running config for v4 but this is not working anymore.
Config Reverse Proxy:
    location /ninja/ {
    proxy_set_header X-Forwarded-Proto https;
    proxy_set_header X-Real-IP  $remote_addr;
    proxy_set_header X-Forwarded-For $remote_addr;
    proxy_set_header Host $host;
    proxy_pass http://192.168.1.11:81/;
    fastcgi_param HTTPS on;
    break;
.env file on invoiceninja server:
APP_URL=“https://www.demo.com/ninja”
nginx conf on invoiceninja server:
server {
listen 81;
server_name invoiceninja;
root /var/www/invoiceninja/public;
any advise?
Have you configured the TRUSTED_PROXIES value in the .env file
yes i tried
TRUSTED_PROXIES=*
TRUSTED_PROXIES=192.168.1.1
I am getting a gray screen and noticed this log in the error log if reverse nginx server:
2023/02/05 18:13:46 [error] 23574#23574: *304524 open() “/var/www/canvaskit/canvaskit.js” failed (2: No such file or directory), client: 192.168.1.153, server: www.demo.com, request: “GET /canvaskit/canvaskit.js HTTP/1.1”, host: “www.demo.com”, referrer: “https://www.demo.com/ninja/”
Interesting side effect:
I tried using the app for iPhone and Mac.
Both are working thru the reverse proxy.
When I try to use the browser I am getting the grey screen.
It may help to change the APP_URL value in the .env file
Should I change the APP_URL to the internal URL?
I am not quite sure, what URL I should put there
@david can you please advise?
I’m not great with nginx proxy, i’ve never really played with it. The only thing I can advise here is that it looks like the system is trying to resolve the js libraries from a rather weird path.
/var/www/
It looks like the vhost for this site is pointing to the root directory /var/ww rather than the diretory of the invoice ninja /public folder?
I am getting more and more confused. Now I can get the login screen and log into the webpage thru a browser. But on the reserve proxy there are errors in the log file.
2023/02/06 09:21:43 [error] 40535#40535: *312522 open() “/var/www/js/pdf.min.js” failed (2: No such file or directory), client: 192.168.1.153, server: www.demo.com, request: “GET /js/pdf.min.js HTTP/1.1”, host: “www.demo.com”, referrer: “https://www.demo.com/ninja/”
2023/02/06 09:21:56 [error] 40536#40536: *312519 open() “/var/www/client/invoice/gmlftxh2mibgjs8b2srplgffpktrjboa/download_pdf” failed (2: No such file or directory), client: 192.168.1.153, server: www.demo.com, request: “GET /client/invoice/gmlftxh2mibgjs8b2srplgffpktrjboa/download_pdf HTTP/1.1”, host: “www.demo.com”, referrer: “https://www.demo.com/ninja/”
The company logo is not displayed, because the pages tries to load it directly?
XMLHttpRequest cannot load http://invoiceninja.localdomain.com:81/storage/u6nq0alhy5hvwgz4z1ffydn268eluxyh/xeGCn7Op7br70RPqr9HzN9TPOCUxI0nPnSDgsZby.png due to access control checks.
I noticed, that i can not open any PDFs in the App, too. Same error as above:
2023/02/06 09:30:52 [error] 40534#40534: *312777 open() “/var/www/client/invoice/gmlftxh2mibgjs8b2srplgffpktrjboa/download_pdf” failed (2: No such file or directory), client: 2.247.245.180, server: www.demo.com, request: “GET /client/invoice/gmlftxh2mibgjs8b2srplgffpktrjboa/download_pdf HTTP/1.1”, host: “www.demo.com”
Should i move invoiceninja to a subfolder on the local server?
You’ll need to double check the vhost configuration.
I think I found the problem, but currently no solution.
I try to redirect a subfolder on reverse proxy to root of invoiceninja server.
Perhapes i need to create a subdomain to get this working.
Well, I created a new certificate and ninja is now running behind the reverse proxy.
I can open the app but noticed, that the pdf and company logo are not displayed. Searching around I found this strange behaviour:
URL is https://ninja.demo.com (also written in .env file)
XMLHttpRequest cannot load http://invoiceninja.localdomain.lan:81/storage/u6nq0alhy5hvwgz4z1ffydn268eluxyh/xeGCn7Op7br70RPqr9HzN9TPOCUxI0nPnSDgsZby.png due to access control checks.
XMLHttpRequest cannot load http://invoiceninja.localdomain.lan:81/client/invoice/vbc0nrkptaphjv4hia5dtnmfhtndvebw/download?t=1675687458626&t=1675687458626 due to access control checks.
It seems, that the system still tries to get the files locally?
This is a path to a file location. what is the HTTP code that is being thrown at this point?
well I added another redirect to the reverse proxy, so that http and https traffic is redirected.
Now it seems to be ok and everything is working.
How does the block look? I’m having a mixed content problem and I guess I need it too.
