Is it possible to run this manually because not sure the cronjob is working f.e. by surfing to a certain page.
The script TestMailServer.php in app/mail is also not working?
i changed env but have the impression it is not working: statics say
Connection could not be established with host smtp.site.com :stream_socket_client(): php_network_getaddresses:
getaddrinfo failed: Name or service not known
“This error can occur due to two reasons. One, there might me an issue with your DNS settings and second, PHP may not be able to get the network addresses for a given host/domain name.”
get also this:
{“message”:“Web cron has not been configured”}
but crons are set, do 'i need to change something in the env.
It is so stupid we have to change this in files etc. Grr
PHP Fatal error: Declaration of Illuminate\Container\Container::get($id) must be compatible with Psr\Container\ContainerInterface::get(string $id) in /home/sites/3f96ba7d3a/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Container/Container.php on line 17
This is most likely a PHP version issue, which version of PHP are you using? This error would be caused by running PHP 8.1
