Hi
How i can round the numbers?
In Switerland CHF ist the smallest ending possibility 05, so we have to round on this.
This is not possible to pay:
90.18 CHF
Should be 90.20 CHF in this case.
Regards
Chris
Hi
90.18 CHF
Regards
Chris
It isn’t currently supported.
Much thanks for the fast answer;-)
OK, when you program this, CHF = rounding to 5. That is fix.
Or different: if you have CHF in your system, then you need also a rounding to 5.
It is a must to work with in Switzerland.
Thanks for the info, I’m surprised we didn’t hear about this sooner.
OK, maybee after you will have much more clients;-)
Hello there,
I’m also looking for something like this, I’m also from Switzerland and I have some clients interested in the system too, but we need to do the rounding.
@hillel don’t you have some kind of code we could introduce to the system to make it work?
No, I don’t have the code
@hillel and since 2017 there’s no update on that?
That’s correct.
Note: the support forum is used to provide support, we track feature requests here:
