Does anyone know if there is an automatic setting to round up seconds (and minutes) so the invoice doesn’t end up with odd numbers like $401.16. Changing it manually is time-consuming.
It isn’t currently supported but you can upvote this issue
Thank you for answering. It’s a shame as the manual change adds to the effort needed to invoice, thereby greatly reducing the value of using Invoice Ninja.
I was using excel but got tired of fiddling with a timer and an invoice in separate apps. Now I have to fiddle around with Ninja settings. Haven’t really saved any time.
