We’re hardening our self hosted invoice ninja instance. By exposing on internet only the relevant services :
- From internet : payement link , client portal
- From our office : backend
It seems like all the backend api endpoints are under : /api
So basically its just adding a new location directive to protect /api ;
One issue we found, is that because “rewrite” takes precedence on “location” that doesn’t work.
So we moved the rewrite from the block’s root to the “location /” directive.
Do you see any reasons to keep the rewrite in the root ?
# Restrict access to /api for private network only
location /api {
allow OFFICE_IP_RANGE;
deny all; # Deny all other access
# Force redirect / to client portal
location = / {
return 301 /client/login;
location / {
# This condition moved from root to here ("rewrite" precedence on "location" directives)
if (!-e $request_filename) {
@david can you please advise?
This worked for me (using docker)
server {
listen 80 default_server;
server_name _;
root /var/www/html/public;
add_header X-Frame-Options "SAMEORIGIN";
add_header X-Content-Type-Options "nosniff";
index index.php;
charset utf-8;
set_real_ip_from 172.22.0.0/16; # Your Docker bridge network
real_ip_header X-Real-IP; # Trust this header
real_ip_recursive on; # Use last non-trusted IP
location ^~ /api {
allow 172.22.0.0/16; # Allow bridge-network access
allow 192.168.1.0/22; # Allow local network access
location / {
location = /robots.txt { access_log off; log_not_found off; }
error_page 404 /index.php;
# Public access to index.php (used by Laravel) e.g. /client/.../...
location = /index.php {
fastcgi_pass invoice-ninja-api-1:9000;
include fastcgi.conf;
location ~ \.php$ {
allow 172.22.0.0/16; # Allow Docker bridge access
deny all;
fastcgi_param SCRIPT_FILENAME $realpath_root$fastcgi_script_name;
include fastcgi_params;
location ~ /\.(?!well-known).* {
deny all;
