I get a methodnotallowed when updating an invoice
I have used newtonjson to create a c# class from a json invoice
then i changed some parameters (not the id of course)
then i do a put but i get a method not allowed
invoice.public_notes=“test”;
client = new RestClient("http://xxxxx.invoiceninja.com");
var request = new RestRequest("api/v1/invoices/{id}", Method.PUT);
// easily add HTTP Headers
request.AddHeader("Content-Type", "application/json");
request.AddHeader("X-Ninja-Token", "xxxx");
request.AddHeader("X-Requested-With", "XMLHttpRequest");
request.AddParameter("id", id);
request.AddJsonBody(invoice);
var res=client.Execute(request);
how can i do an update ?
is there a postman sample available?
December 28, 2017, 8:18pm
One problem I see is you’re using HTTP instead of HTTPS, the API will redirect to HTTPS which may cause the error.
Hi, https is not working it’s with http
pls can you help me ?
December 28, 2017, 10:38pm
4
If you’re using invoiceninja.com you won’t be able to use HTTP.
Are you seeing a specific error with HTTPS?
I don’t understand it
i can have with postman a get operation
http://pureautomation.invoiceninja.com/api/v1/invoices/13
its http if i change to https it’s not working
can you pls create a postman script ?
December 29, 2017, 12:27am
6
We don’t support accessing our API using HTTP.
If you send a request using HTTP it will 301 forward to HTTPS, I assume the code you’re using is handling the 301 for a GET but not a PUT.
I am trying this
curl -X PUT https://app.invoiceninja.com/api/v1/invoices/17 -H “Content-Type:application/json” -d ‘{“id”: 17,”client_id”: 40 }’ -H “X-Ninja-Token: tokenid” -H “X-Requested-With: XMLHttpRequest”
I get following
{“error”:{“message”:“Invalid token”}}curl: (6) Could not resolve host: 17,”client_id”
i am sure my token is valid because i use it for the get operation
December 29, 2017, 12:31am
8
What are you trying to do, we don’t support changing the client id for an invoice.
Hi i want to update the public_notes
state : paid / etc
later i want to add invoiceitems
which fields can be changed ?
in fact i am serializing a complete invoice and the change some fields
and put it back
so which fields can be changed ?
December 29, 2017, 12:41am
11
Pretty much every field but the client it.
The error you’re seeing is pretty odd, it looks like you may be trying to send two requests.
Make sure you aren’t copy/pasting from this forum, unless the code is enclosed in backticks the quotes are changed.
i am using postman to test
PUT command
URL : https://app.invoiceninja.com/api/v1/invoices/17
X-Ninja-Token:tokenid
X-Requested-With:XMLHttpRequest
i want to change public_notes of invoice 17
in body data i put
“id”:17,
“public_notes”: “dsqfsdf”
then i have error : something went wrong
December 29, 2017, 12:52am
13
To update an existing invoice you need to pass back all of the data, I think the error is occurring because the invoice_items property isn’t set.
