Is it possible to add a scan of a clients passport into his data?
Koen
Koen
We don’t support attaching documents to clients.
Maybe you could use a 3rd party storage solution and add the link to the image in a custom field.
Hey there! I saw your reply and wanted to offer some advice. Adding a passport scan to client info is a smart move for security reasons. I’m not sure if there are any third-party solutions out there, but it’s worth doing some research to find out. As for using a fake ID, you should first know how to pay for a fake id. IMO, it’s a nice option, just find a reputable resource. If you’re worried about the cost of the passport scan software, there are often free or low-cost options available online. Just do a bit of digging, and you might find something that works for you.
