i am not sure if i just can not find the correct field combination or it is not here - but it would be great if i can get the following reports:
Hours from tasks which are not invoiced of chosen client
Hours from tasks which are not invoiced in total (where i can see open hours per client)
Also would be nice to have. How many hours did i worked today (so sum of time of todays tasks, all states)
Also i would +1 to save favorites in reports as another user suggested.
Thx for helping,
BR Andreas
June 19, 2023, 3:40pm
Thanks for the feedback!
We plan to add a task item report which may help with this.
Hello @hillel ,
thank you for the fast feedback. And great to hear .
BR Andreas
Also a good place to display the sum of the time of already finished tasks or open tasks could be in tasks module.
Because there these filter options already exist (filter bar, filter if active / archived, filter by status):
June 20, 2023, 6:05am
5
Thanks for the suggestion!
It looks like you’re using the macOS app, we’re developing desktop widgets which may also be an option.
Yes i am using the macOS app. Oh - desktop widgets with that functionality would be great to have
June 20, 2023, 8:57am
7
Great to hear! The initial version of the widget will be basic (just invoices/payments) but we plan to support more use cases in the future.
cc @david
I tried to understand how Reports are working in source code. But i think it is beyond my capabilities in this field.
Is there any chance to get Reports with stats of not invoiced hours per customer?
Or the sum of time below the task table as shown in the above screenshot?
Or can you give me a push in the right direction how i can achieve it myself?
Thx, regards, Andreas
July 4, 2023, 11:33am
9
Feel free to create an issue here to request the feature:
If you have any specific questions about the code I’m happy to try to help.
