Reorganizing the dashboard (move, hide, fold elements)
I’m wondering if it’s possible to reorganize the dashboard.
To move, hide or fold dashboard-windows (elements).
Like in Wordpress, where I can do all this things …
Is there a possibility or a future plan?
THX and regards
This isn’t currently supported.
It’s possible we’d add it in the future but it isn’t currently a high priority.
This is a pity. This would speed up my workflow …
I hope this will be implemented in the future.
THX and regards.
Maybe you could use a third party dashboard service, the following are supported by Zapier.
https://www.klipfolio.com
https://www.geckoboard.com
https://www.dasheroo.com
Many thanks.
I will check them.
regards
