vco1
1
Is it possible to remove columns from the invoice table in the pdf? I don’t need a Name (product) column, just the description would be fine.
So far I’ve been able to build the pdf just the way my paper invoice is, but I’m not sure how the invoice (line items) table is working.
On all but the ‘Bold’ design the column should be hidden if the product name is blank.
vco1
3
Didn’t notice that. Thanks!
Would it be possible to change the Invoice table, or is this hard coded? For example can I change the order of the columns?
4
Most changes to the table (for example changing the order) required changes to the code.
