Remove watermark on invoices (v5) [SOLVED]
I’m not using the self-hosted solution but the one directly from invoice ninja.
I moved to v5 because I neded a more robust API (integrating with ios shortcuts), especially for creating invoices.
However, on v5 all my invoices PDFs have a big invoiceninja watermark on them. I remember having that on v4 and finding a setting in the invoices “customization” to remove it, but I can’t seem to find it in v5. Where can I do that?
Do you have a paid plan, upgrading should remove the Invoice Ninja branding.
Note: you’ll need to resave old invoices for them to be updated.
@david maybe we can clear the PDF cache when a user upgrades?
Hey, I do I’m on the pro plan :slight_smile: After more investigating, it seems that since I had no company logo, it displayed the Invoice Ninja logo by default. I solved that by uploading a blank pixel as my logo haha.
Thanks for the update, glad to hear it’s solved!
@david @ben we should correct this so no logo is shown once paid
How simple is the watermark removal process? I want to upgrade once I’ve sorted out my issues with self hosted install but would first like to know how simple it is. Would I need to edit or save any settings or would this just work after I’ve paid?
Its been a bit of a headache trying to set up self hosting so far due to many different instructions because different OS and web servers and possible tools you could use so I’m hoping this upgrade to a watermark removal is painless.
