I issued a number of items in a quote for my customer to choose from, and don’t need a total or subtotal field.
Is there any way I can remove the Total and Subtotal Field in my Quote?
Regards,
Voon Yee
Regards,
Voon Yee
It may be possible using a custom design
Can you advise how to create a custom design for Quote?
You can create a custom design on Settings > Invoice Design > Customize
Can that create a custom design for Quote?
That seems to create a custom design for Invoice only.
Yes, custom designs can be used for invoices or quotes
