I am curious if there is a way to send reminder e-mails for quotes. The app works perfectly for invoices, but it would be nice to have reminders for quotes work the same way.
If you’re self-hosting you could remove the invoiceType filter here:
Could you expand on this please?
Do you mean the line that says:
Account $account, $filterEnabled = true)
and change that to false? Or do you mean the commented out lines above it?
* @param Account $account
* @return mixed
The Invoice::invoiceType(INVOICE_TYPE_STANDARD) needs to be changed.
Note: there may be other changes required, I haven’t tested this…
Gotcha, I’ll keep that in mind. Thanks!
