Just noticed that I had a batch of invoices setup and active on recurring that were supposed to go out on May 14th and never did. Had been working fine previously, as one had been previously sent on 5/1. What can I look for as an issue and what changed?
Thanks for the response. There were no invoices generated at all. The next send date still indicates May 14th, 2025. Screenshot is below. (Side question - should autobill be enabled? If so, somehow they all changed to Off…)
It seems there is a bug in an actual version, on my site it’s a self hosted environment. Test mails are running fine. But no new invoices and also previously generated (now resent) emails arent working. (Over more than one company).
I already reset the configuration.
Question in this case is; which is now the proper configuration place:
Backend email or .env file?
And furthermore the bug, when I want to test an email setup in the android app I have to put in every time the user and password of the SMTP server, because it’s taking the ***** of the in app shown fields as user and password not the predefined (and working) settings.
