Recurring Invoices not sending
Recurring Invoices are not being sent as scheduled, enabled auto-billing for recurring invoices is not working either. Is there a setting I am missing?
Have you configured the cron and are the recurring invoices set to pending/active?
Yes, its set to active. Cron has always been an issue, I’ve tried everything to have it configured correctly and it always gives me an error of “The Crons need to be enabled”. In the past you have referred me to the github records and I’ve followed them and still nothing. So maybe its just not compatible, don’t know.
If the cron isn’t configured the recurring invoices won’t be sent.
I suggest trying to run the cron from CLI without the >> part to check the output.
yea, nothing, no luck
What’s the output from the CLI?
