system
1
I have a client with the following recurring invoice which for some reason did not produce this morning:
http://prntscr.com/lt5e27
I also checked and I have the following cron jobs set:
http://prntscr.com/lt5ekj
Then I opened the recurring invoice and saw this:
http://prntscr.com/lt5euy
So all appears to be setup but the invoices are not running.
Any suggestions…?
Maybe it’s a timezone issue, you may want to run the cron later in the day.
system
3
Thanks Hillel
I thought of that and cjhecked, the timezone is set correctly on the server, it’s UK time.
4
I think the app expects the server to be using UTC
system
5
OK, well as this is shared hosting space I don’t know how I might achieve this. Any suggestions…?
6
Running the cron later in the day may help.
system
7
Thanks Hillel
I’ve tried that and also added an email address to send a report and it’s not even doing that to say nothing happened.
system
8
