There seems to be a really major bug that is costing me time and money now.
I noticed today that many of my recurring invoices did not send, and the ones that did, did not auto-charge as they were supposed to.
I manually ran this command:
php artisan ninja:send-recurring
In AuthorizeCreditCard.php line 106:
Call to a member function getResultCode() on array
Seems to generate one invoice, but the autocharge is not working.
Ok looks like the problem is even worse than I expected.
The invoices are generated, but NOT marked paid when in fact there is a charge pending in Authorize.net
Running 5.3.1
September 1, 2021, 3:58pm
3
I was able to generate the invoices by running the command above tons of times (Would gen one customer’s invoices each time, even if the customer had more than one invoice), but confirmed it did charge the customers but did not mark the invoices paid in Invoice Ninja.
I did go to the client portal and run a payment with a saved card on a few and those worked just fine (marking paid properly), but since they had already been charged this ended up double charging because the auto-charge worked, but did not mark paid.
I am manually going through and entering payments now to avoid double charging.
david
September 2, 2021, 6:31am
5
@xtekrepair
I’ve tagged v5.3.4 there are fixes in there for autobilling.
I’m not sure what the issue is with Authorize.net , it sounds like something is failing after the payment is processed causing the payment record to not be recorded.
If you have a error logs please send it through.
Thank you so much! You guys are great.
Here is part of (Too big for post) the log:
[2021-08-27 00:00:02] production.INFO: latest version = 5.3.1
[2021-08-27 00:00:03] production.INFO: updating currencies
[2021-08-27 00:00:03] production.INFO: latest version = 5.3.1
[2021-08-27 00:30:02] production.INFO: Performing Autobilling 2021-08-27 12:30:02
[2021-08-27 23:39:00] production.INFO: https://test.com/tmp_pdf/O2FO79QXcFx6z3vHDmxK2bl7hAj7dO4k
[2021-08-27 23:39:05] production.INFO: https://test.com/tmp_pdf/J7JK44UzyiYdvR9hH3JOiboBHnhHj6sE
[2021-08-27 23:41:39] production.INFO: https://test.com/tmp_pdf/K3GKOV0M0Y1NyiGvqRSLim5igMYKM4uo
[2021-08-28 00:00:01] production.INFO: latest version = 5.3.1
[2021-08-28 00:00:02] production.INFO: updating currencies
[2021-08-28 00:00:02] production.INFO: latest version = 5.3.1
[2021-08-28 00:30:01] production.INFO: Performing Autobilling 2021-08-28 12:30:01
[2021-08-29 00:00:02] production.INFO: latest version = 5.3.1
[2021-08-29 00:00:03] production.INFO: updating currencies
[2021-08-29 00:00:04] production.INFO: latest version = 5.3.1
[2021-08-29 00:30:01] production.INFO: Performing Autobilling 2021-08-29 12:30:01
[2021-08-30 00:00:01] production.INFO: latest version = 5.3.1
[2021-08-30 00:00:07] production.INFO: updating currencies
[2021-08-30 00:00:07] production.INFO: latest version = 5.3.1
[2021-08-30 00:30:02] production.INFO: Performing Autobilling 2021-08-30 12:30:02
[2021-08-30 16:36:08] production.INFO: https://test.com/phantom/invoice/Zo1LWPmF1uq2dGOZ3uzzq8Fh8eIGDjfAWCiRTXLNHjjwtVmx7KQnIMTDJDb3TPHP?phantomjs_secret=password
[2021-08-30 16:36:11] production.INFO: https://test.com/phantom/invoice/Zo1LWPmF1uq2dGOZ3uzzq8Fh8eIGDjfAWCiRTXLNHjjwtVmx7KQnIMTDJDb3TPHP?phantomjs_secret=password
[2021-08-30 16:36:15] production.INFO: https://test.com/phantom/invoice/Zo1LWPmF1uq2dGOZ3uzzq8Fh8eIGDjfAWCiRTXLNHjjwtVmx7KQnIMTDJDb3TPHP?phantomjs_secret=password
[2021-08-30 18:56:11] production.INFO: https://test.com/tmp_pdf/gGn0em878nQ1gA5XCd4oBlRodSSXRdZL
[2021-08-31 00:00:01] production.INFO: latest version = 5.3.1
[2021-08-31 00:00:06] production.INFO: updating currencies
[2021-08-31 00:00:07] production.INFO: latest version = 5.3.1
[2021-08-31 00:30:01] production.INFO: Performing Autobilling 2021-08-31 12:30:01
[2021-08-31 16:56:06] production.INFO: https://test.com/tmp_pdf/aqpBD625lwnX06JGwA00MYTcXGOjVXMF
[2021-08-31 16:56:11] production.INFO: https://test.com/tmp_pdf/TVZPvQ8j6aeYQmOfl6CEIzUgHSRrkYQS
[2021-08-31 16:56:18] production.INFO: https://test.com/tmp_pdf/FxXNjLvBT5Omdbt1gdOFvptfYJxPeFwr
[2021-08-31 16:56:23] production.INFO: https://test.com/tmp_pdf/41wHq2YTnrVq9Sgackghec5HX6Eo3T6B
[2021-08-31 16:56:27] production.INFO: https://test.com/tmp_pdf/Gk18yEE3ePBGiqs7VKBQjAqw31o8PDVN
[2021-08-31 16:56:31] production.INFO: https://test.com/tmp_pdf/m3muAL0YqfXtJ8orYUy0JTgtjfEPsjRR
[2021-08-31 16:56:43] production.INFO: https://test.com/tmp_pdf/v1kTDYEfnFuFnmqWxwdzKSjesNZJnDnP
[2021-08-31 16:56:50] production.INFO: https://test.com/tmp_pdf/6fgAvLwc7k4NWytiifzsu7UuXurfhgAZ
[2021-08-31 16:56:55] production.INFO: https://test.com/tmp_pdf/PcTimDxAbRrGe2ZRok9fnuExmps8M9Rz
[2021-08-31 16:57:05] production.INFO: https://test.com/tmp_pdf/DLoVc9Z2OhCZn7mjLYuBRknflkjTc66Z
[2021-08-31 16:57:27] production.INFO: https://test.com/tmp_pdf/IbWVpUTNbLV0XPQlvVn8mW2HDqinTsK4
[2021-08-31 16:57:48] production.INFO: https://test.com/tmp_pdf/I15iQPxWFNhICZwxZ4PJS5vZiP3NveBb
[2021-08-31 16:57:57] production.INFO: https://test.com/tmp_pdf/2uD8tRgpYtNXg6BY9dOk92t0eKQaV7Q2
[2021-08-31 16:58:02] production.INFO: https://test.com/tmp_pdf/LunSaDmmbj9ZARKVYphX9BLGVmI4CnHz
[2021-08-31 16:58:05] production.INFO: https://test.com/tmp_pdf/SUZHc8kHUwgZc781GDUb9spxBlgriCUJ
[2021-08-31 16:59:37] production.INFO: https://test.com/tmp_pdf/TSX3lDMjHcZ08LZnvyAv5PzqhDuO13nj
[2021-08-31 16:59:45] production.INFO: https://test.com/tmp_pdf/9nGrm98JixmldgSS6ojyrFPpj0jMSDoQ
[2021-08-31 16:59:52] production.INFO: https://test.com/tmp_pdf/LgC0vyXf4JWTS7PWnW1YPugjVnJqIt3R
[2021-08-31 16:59:59] production.INFO: https://test.com/tmp_pdf/y6eDUJD4NrA3rzGGnlNUuc8j6PB1XwOA
[2021-08-31 17:28:09] production.INFO: https://test.com/tmp_pdf/vBqY7o92UcFg80M7NAUpU4yKuLkitPFP
[2021-08-31 17:28:13] production.INFO: https://test.com/tmp_pdf/f71pWQchBAfoV04lMvkYy40gDMoeFmnR
[2021-09-01 00:00:02] production.INFO: latest version = 5.3.2
[2021-09-01 00:00:10] production.INFO: updating currencies
[2021-09-01 00:00:14] production.INFO: https://test.com/phantom/invoice/54D6numVPwJXxKNFBEJiQIlAmDcrbvhLh6NSQt14Q4y0MOcyDwRoOVDO6a2Q4jLz?phantomjs_secret=password
[2021-09-01 00:00:21] production.INFO: https://test.com/phantom/invoice/KhPQQCz3sdkJLWvHxMUfgJDCH6sULJENa26fWNzmS9lDlsy9dpsyBFOJQeamYpfS?phantomjs_secret=password
[2021-09-01 00:00:26] production.INFO: balance remains to be paid!!
[2021-09-01 00:00:27] production.ERROR: Call to a member function getResultCode() on array {"exception":"[object] (Error(code: 0): Call to a member function getResultCode() on array at /var/www/test.com/app/PaymentDrivers/Authorize/AuthorizeCreditCard.php:106)
#0 /var/www/test.com/app/PaymentDrivers/AuthorizePaymentDriver.php(108): App\\PaymentDrivers\\Authorize\\AuthorizeCreditCard->tokenBilling()
#1 /var/www/test.com/app/Services/Invoice/AutoBillInvoice.php(100): App\\PaymentDrivers\\AuthorizePaymentDriver->tokenBilling()
#2 /var/www/test.com/app/Services/Invoice/InvoiceService.php(230): App\\Services\\Invoice\\AutoBillInvoice->run()
#3 /var/www/test.com/app/Jobs/RecurringInvoice/SendRecurring.php(134): App\\Services\\Invoice\\InvoiceService->autoBill()
#4 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\\Jobs\\RecurringInvoice\\SendRecurring->handle()
#5 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#6 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#7 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#8 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Container.php(611): Illuminate\\Container\\BoundMethod::call()
#9 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\\Container\\Container->call()
#10 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Bus\\Dispatcher->Illuminate\\Bus\\{closure}()
#11 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#12 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\\Pipeline\\Pipeline->then()
#13 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Foundation/Bus/Dispatchable.php(69): Illuminate\\Bus\\Dispatcher->dispatchNow()
#14 /var/www/test.com/app/Jobs/Cron/RecurringInvoicesCron.php(64): App\\Jobs\\RecurringInvoice\\SendRecurring::dispatchNow()
#15 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Collections/Traits/EnumeratesValues.php(234): App\\Jobs\\Cron\\RecurringInvoicesCron->App\\Jobs\\Cron\\{closure}()
#16 /var/www/test.com/app/Jobs/Cron/RecurringInvoicesCron.php(66): Illuminate\\Support\\LazyCollection->each()
#17 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\\Jobs\\Cron\\RecurringInvoicesCron->handle()
#18 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#19 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#20 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#21 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Container.php(611): Illuminate\\Container\\BoundMethod::call()
#22 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\\Container\\Container->call()
#23 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Bus\\Dispatcher->Illuminate\\Bus\\{closure}()
#24 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#25 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\\Pipeline\\Pipeline->then()
#26 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/Schedule.php(180): Illuminate\\Bus\\Dispatcher->dispatchNow()
#27 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/Schedule.php(142): Illuminate\\Console\\Scheduling\\Schedule->dispatchNow()
#28 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\\Console\\Scheduling\\Schedule->Illuminate\\Console\\Scheduling\\{closure}()
#29 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Closure->__invoke()
#30 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#31 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#32 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#33 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Container.php(611): Illuminate\\Container\\BoundMethod::call()
#34 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/CallbackEvent.php(79): Illuminate\\Container\\Container->call()
#35 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/ScheduleRunCommand.php(143): Illuminate\\Console\\Scheduling\\CallbackEvent->run()
#36 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/ScheduleRunCommand.php(102): Illuminate\\Console\\Scheduling\\ScheduleRunCommand->runEvent()
#37 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\\Console\\Scheduling\\ScheduleRunCommand->handle()
#38 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#39 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#40 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#41 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Container.php(611): Illuminate\\Container\\BoundMethod::call()
#42 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Command.php(136): Illuminate\\Container\\Container->call()
#43 /var/www/test.com/vendor/symfony/console/Command/Command.php(256): Illuminate\\Console\\Command->execute()
#44 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Command.php(121): Symfony\\Component\\Console\\Command\\Command->run()
#45 /var/www/test.com/vendor/symfony/console/Application.php(971): Illuminate\\Console\\Command->run()
#46 /var/www/test.com/vendor/symfony/console/Application.php(290): Symfony\\Component\\Console\\Application->doRunCommand()
#47 /var/www/test.com/vendor/symfony/console/Application.php(166): Symfony\\Component\\Console\\Application->doRun()
#48 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Application.php(92): Symfony\\Component\\Console\\Application->run()
#49 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(129): Illuminate\\Console\\Application->run()
#50 /var/www/test.com/artisan(37): Illuminate\\Foundation\\Console\\Kernel->handle()
#51 {main}
[2021-09-01 00:00:28] production.INFO: latest version = 5.3.2
[2021-09-01 00:30:02] production.INFO: Performing Autobilling 2021-09-01 12:30:02
[2021-09-01 00:30:02] production.INFO: Firing autobill for 1 - 009229
[2021-09-01 00:30:02] production.INFO: balance remains to be paid!!
[2021-09-01 00:30:04] production.ERROR: Call to a member function getResultCode() on array {"exception":"[object] (Error(code: 0): Call to a member function getResultCode() on array at /var/www/test.com/app/PaymentDrivers/Authorize/AuthorizeCreditCard.php:106)
#3 /var/www/test.com/app/Jobs/Cron/AutoBillCron.php(99): App\\Services\\Invoice\\InvoiceService->autoBill()
#4 /var/www/test.com/app/Jobs/Cron/AutoBillCron.php(65): App\\Jobs\\Cron\\AutoBillCron->runAutoBiller()
#5 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Collections/Traits/EnumeratesValues.php(234): App\\Jobs\\Cron\\AutoBillCron->App\\Jobs\\Cron\\{closure}()
#6 /var/www/test.com/app/Jobs/Cron/AutoBillCron.php(66): Illuminate\\Support\\LazyCollection->each()
#7 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\\Jobs\\Cron\\AutoBillCron->handle()
#8 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#9 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#10 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#11 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Container.php(611): Illuminate\\Container\\BoundMethod::call()
#12 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\\Container\\Container->call()
#13 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Bus\\Dispatcher->Illuminate\\Bus\\{closure}()
#14 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#15 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\\Pipeline\\Pipeline->then()
#16 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/Schedule.php(180): Illuminate\\Bus\\Dispatcher->dispatchNow()
#17 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/Schedule.php(142): Illuminate\\Console\\Scheduling\\Schedule->dispatchNow()
#18 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\\Console\\Scheduling\\Schedule->Illuminate\\Console\\Scheduling\\{closure}()
#19 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Closure->__invoke()
#20 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#21 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#22 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#23 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Container.php(611): Illuminate\\Container\\BoundMethod::call()
#24 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/CallbackEvent.php(79): Illuminate\\Container\\Container->call()
#25 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/ScheduleRunCommand.php(143): Illuminate\\Console\\Scheduling\\CallbackEvent->run()
#26 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Scheduling/ScheduleRunCommand.php(102): Illuminate\\Console\\Scheduling\\ScheduleRunCommand->runEvent()
#27 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\\Console\\Scheduling\\ScheduleRunCommand->handle()
#28 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#29 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#30 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#31 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Container/Container.php(611): Illuminate\\Container\\BoundMethod::call()
#32 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Command.php(136): Illuminate\\Container\\Container->call()
#33 /var/www/test.com/vendor/symfony/console/Command/Command.php(256): Illuminate\\Console\\Command->execute()
#34 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Command.php(121): Symfony\\Component\\Console\\Command\\Command->run()
#35 /var/www/test.com/vendor/symfony/console/Application.php(971): Illuminate\\Console\\Command->run()
#36 /var/www/test.com/vendor/symfony/console/Application.php(290): Symfony\\Component\\Console\\Application->doRunCommand()
#37 /var/www/test.com/vendor/symfony/console/Application.php(166): Symfony\\Component\\Console\\Application->doRun()
#38 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Console/Application.php(92): Symfony\\Component\\Console\\Application->run()
#39 /var/www/test.com/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(129): Illuminate\\Console\\Application->run()
#40 /var/www/test.com/artisan(37): Illuminate\\Foundation\\Console\\Kernel->handle()
#41 {main}
[2021-09-01 00:40:28] production.INFO: https://test.com/tmp_pdf/yGzQPbZGqzUkZ446qv77HPv4FxWJ6Kxk
[2021-09-01 01:00:05] production.INFO: https://test.com/phantom/invoice/d8fgKKAbyo1JCl5ZzE8uzs3z68iT6z8ZeiNhKmTwgvumj2AJlemg15MQOwnj5LSP?phantomjs_secret=password
[2021-09-01 01:00:11] production.INFO: https://test.com/phantom/invoice/jtgsVKszjzQAVpTIAy0CVwVtPAdkVpWAnTTWWd9nKHrANtu2kVSuZKR4boaNKMlz?phantomjs_secret=password
[2021-09-01 01:00:17] production.INFO: https://test.com/phantom/invoice/vIk7DmnUnFCdjMOCtM8QzpdgAGrdR7BgIvoxzHQpSSzjTobmTpABYQmmZGHVi6iK?phantomjs_secret=password
[2021-09-01 01:00:22] production.INFO: balance remains to be paid!!
[2021-09-01 01:00:23] production.ERROR: Call to a member function getResultCode() on array {"exception":"[object] (Error(code: 0): Call to a member function getResultCode() on array at /var/www/test.com/app/PaymentDrivers/Authorize/AuthorizeCreditCard.php:106)
#51 {main}
Another note reguarding authorize.net .
If I have an invoice and I just click pay from the client portal it works just fine.
Only the auto-pay/recurring invoices error out.
david
September 7, 2021, 6:28am
8
@xtekrepair
I’ve tagged 5.3.7
I’ve included some small changes for autobilling, please let me know if this resolves the issue you are seeing.
Ok so the recurring billing was today, and it did not work again. I went ahead and forced the invoices and they all went out (php artisan ninja:send-recurring). None of them were autocharged. I had to manually goto each invoice and run the cards through the customer portal. Interestingly two of them had declines, not sure if that is related, like something stops on a decline as they were the first two. I will send another reply with the log information.
[2021-09-15 00:00:22] production.INFO: latest version = 5.3.10
[2021-09-15 00:30:02] production.INFO: Performing Autobilling 2021-09-15 12:30:02
[2021-09-15 00:30:02] production.INFO: Firing autobill for 1 - 009298
[2021-09-15 00:30:02] production.INFO: Auto Bill - balance remains to be paid!! - 39.990000
[2021-09-15 00:30:03] production.ERROR: Call to a member function getResultCode() on null {"exception":"[object] (Error(code: 0): Call to a member function getResultCode() on null at /var/www/test.com/app/PaymentDrivers/Authorize/AuthorizeCreditCard.php:106)
#0 /var/www/test.com/app/PaymentDrivers/AuthorizePaymentDriver.php(110): App\\PaymentDrivers\\Authorize\\AuthorizeCreditCard->tokenBilling()
#1 /var/www/test.com/app/Services/Invoice/AutoBillInvoice.php(115): App\\PaymentDrivers\\AuthorizePaymentDriver->tokenBilling()
#2 /var/www/test.com/app/Services/Invoice/InvoiceService.php(236): App\\Services\\Invoice\\AutoBillInvoice->run()
#3 /var/www/test.com/app/Jobs/Cron/AutoBillCron.php(122): App\\Services\\Invoice\\InvoiceService->autoBill()
#4 /var/www/test.com/app/Jobs/Cron/AutoBillCron.php(73): App\\Jobs\\Cron\\AutoBillCron->runAutoBiller()
#6 /var/www/test.com/app/Jobs/Cron/AutoBillCron.php(74): Illuminate\\Support\\LazyCollection->each()
#41 {main}
[2021-09-15 01:00:06] production.INFO: https://test.com/phantom/invoice/XBx9SVarscvg85jqO313hAmSIqNOxZhZeXMh2ZyI7pzyrYbR75d7mfoQSm1ABGq8?phantomjs_secret=mysecret
[2021-09-15 01:00:11] production.INFO: Auto Bill - balance remains to be paid!! - 84.990000
[2021-09-15 01:00:12] production.ERROR: Call to a member function getResultCode() on array {"exception":"[object] (Error(code: 0): Call to a member function getResultCode() on array at /var/www/test.com/app/PaymentDrivers/Authorize/AuthorizeCreditCard.php:106)
#3 /var/www/test.com/app/Jobs/RecurringInvoice/SendRecurring.php(136): App\\Services\\Invoice\\InvoiceService->autoBill()
#14 /var/www/test.com/app/Jobs/Cron/RecurringInvoicesCron.php(67): App\\Jobs\\RecurringInvoice\\SendRecurring::dispatchNow()
#16 /var/www/test.com/app/Jobs/Cron/RecurringInvoicesCron.php(73): Illuminate\\Support\\LazyCollection->each()
#51 {main}
[2021-09-15 02:00:05] production.INFO: https://test.com/phantom/invoice/51Iru0kzNz3iWjvPYwTvITwVxGGzWYYem9LdtQJUvCDToevXvhuTmqfQ5VXrQd1D?phantomjs_secret=mysecret
[2021-09-15 02:00:09] production.INFO: Auto Bill - balance remains to be paid!! - 59.990000
[2021-09-15 02:00:10] production.ERROR: Call to a member function getResultCode() on array {"exception":"[object] (Error(code: 0): Call to a member function getResultCode() on array at /var/www/test.com/app/PaymentDrivers/Authorize/AuthorizeCreditCard.php:106)
#51 {main}
[2021-09-15 15:10:23] production.INFO: https://test.com/phantom/invoice/51Iru0kzNz3iWjvPYwTvITwVxGGzWYYem9LdtQJUvCDToevXvhuTmqfQ5VXrQd1D?phantomjs_secret=mysecret
[2021-09-15 15:10:26] production.INFO: https://test.com/phantom/invoice/51Iru0kzNz3iWjvPYwTvITwVxGGzWYYem9LdtQJUvCDToevXvhuTmqfQ5VXrQd1D?phantomjs_secret=mysecret
[2021-09-15 15:10:30] production.INFO: https://test.com/phantom/invoice/51Iru0kzNz3iWjvPYwTvITwVxGGzWYYem9LdtQJUvCDToevXvhuTmqfQ5VXrQd1D?phantomjs_secret=mysecret
[2021-09-15 15:10:48] production.INFO: https://test.com/phantom/invoice/XBx9SVarscvg85jqO313hAmSIqNOxZhZeXMh2ZyI7pzyrYbR75d7mfoQSm1ABGq8?phantomjs_secret=mysecret
[2021-09-15 15:10:50] production.INFO: https://test.com/phantom/invoice/XBx9SVarscvg85jqO313hAmSIqNOxZhZeXMh2ZyI7pzyrYbR75d7mfoQSm1ABGq8?phantomjs_secret=mysecret
[2021-09-15 15:10:55] production.INFO: https://test.com/phantom/invoice/XBx9SVarscvg85jqO313hAmSIqNOxZhZeXMh2ZyI7pzyrYbR75d7mfoQSm1ABGq8?phantomjs_secret=mysecret
[2021-09-15 15:12:28] production.INFO: https://test.com/phantom/invoice/qME9eJaGBaSZEFrUrdZTEQw4DprVQR0StQ0KAC7We9di56ssfIa4UqVEyujEwPML?phantomjs_secret=mysecret
[2021-09-15 15:12:30] production.INFO: https://test.com/phantom/invoice/qME9eJaGBaSZEFrUrdZTEQw4DprVQR0StQ0KAC7We9di56ssfIa4UqVEyujEwPML?phantomjs_secret=mysecret
[2021-09-15 15:12:34] production.INFO: https://test.com/phantom/invoice/qME9eJaGBaSZEFrUrdZTEQw4DprVQR0StQ0KAC7We9di56ssfIa4UqVEyujEwPML?phantomjs_secret=mysecret
david
September 15, 2021, 10:36pm
11
Thanks this is helpful, i can recreate this. I’ve check in a fix, available in the next release.
Angel
September 17, 2021, 4:30pm
12
@david The autobilling on recurring invoices is working just fine but I have to manually “push” the payments through. Is there a fix for this coming soon? If my client has an authorized payment method on file the old version would process the payment. This version seems to have a bug.
david
September 17, 2021, 9:28pm
13
I think the issue here is the setting in Settings > Online Payments.
You may have auto bill on Due Date set. You will want to change this to on Send Date
I just checked and the Auto Bill is set to ‘Send Date’
david
September 18, 2021, 12:31am
15
@xtekrepair
if you have command line access please run
php artisan tinker
AutoBillCron::dispatchNow();
What am I looking for when I run this?
david
September 18, 2021, 12:52am
17
This force runs the autobilling, if there are outstanding invoices to be bill this command will process them.
The idea here is it will expose any errors in the logs if something is going wrong.
Ok thanks, however I do not have any autobilling till the beginning of next month.
I am planning on upgrading to the new version today also. Thank you for the tips.
If there is a problem I will use that command.
