I am having a problem, after I recovered my database I keep running into this error. Its only after the terms of use box shows up. Apparently the terms of use has already been accepted before. So is this what’s generating the error? Am not sure if there is something else causing the error. Please advice.
Version Installed - 4.4.3
[2018-05-28 12:44:04] production.ERROR: Illuminate\Database\QueryException [42S22] : /public_html/scoprire.nyc/ninja3/vendor/laravel/framework/src/Illuminate/Database/Connection.php [Line 647] => SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘accepted_terms_version’ in ‘field list’ (SQL: update users set updated_at = 2018-05-28 12:44:04, accepted_terms_version = 1.0.1, accepted_terms_timestamp = 2018-05-28 12:44:04, accepted_terms_ip = 206.75.114.174 where id = 1) {“context”:“PHP”,“user_id”:1,“account_id”:“1”,“user_name”:"",“method”:“POST”,“user_agent”:“Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:60.0) Gecko/2010010-----1 Firefox/60.0”,“locale”:“en”,“ip”:"-",“count”:1,“is_console”:“no”,“is_api”:“no”,“db_server”:“mysql”,“url”:“accept_terms”}
The page opens fine and I manage to log in, but once am in the dashboard the terms or use box shows up. In the background everything looks fine. When I accept the terms of use the page redirects me and shows me a whole list of errors.
I installed a new copy of the script since the old one was messed up for some reason. In a different directory and used the old database instead of the new one.
No I did not update to the same version rather the newer version. So this is whats causing the problem. So I have to do the migration in-order to resolve the problem between the different versions?
Load / update how? When I tried to use the database from a recovered Invoice ninja app it keeps giving me the error. Like I sent you previously. So is there any other way I can load / update the database to the current version of Invoice Ninja app? The strange thing is that It logs me in and redirects me to the dashboard. So its only when I click on terms of use it crashes. Can you please advice?
You can load update by just going to http://yoururl/update. So based on your screenshots, it looks like that would be scoprire.nyc/ninja3/public/update.
