React UI Login - API Secret?
I have the API secret configured for login and it works on the old UI. While logged in, I switched to the React UI by pressing the React icon at the top. That worked fine. I then logged out to test KeePassXC integration (it works!) but there is no field on the login page for the API secret so I can’t log in anymore. Am I missing something?
I am on the latest docker build released about 4 days ago (docker image id: 3709c4a7dd33)
@david can you please advise?
We’ll get this added
Is there a way I can disable the react UI so I can get back in? Maybe some SQL db command?
Here’s the SQL command:
