There are any way to disable this REACT interface? Is full of bugs and i want back to previous Flutter.
You can change back to the Flutter app by running this SQL command.
If you can provide details for any issues youâre seeing weâll make sure theyâre corrected.
Thanks, is work.
Some of the bug is , Activate Company show is not activate and at Notification you change what notification whant and after Save and Refresh is same
Some help if you can:
How i can change name o Gross line total with something custom
I canât find option in Localization for customize this line:
Or if you can to put in Romanian translation like in this image:
I also made the switch, and Expenses and Reoccurring Expenses are missing from the menu. Checked Enabled modules, and both are toggled âOnâ. Viewing Expenses under a Client just loads a blank white space, no table or anything.
@Lionboy you should be able to add a custom translation label.
@classicpatrick not all modules are supported yet with the new app, weâre developing them over time.
I do custom translation in texts.php
Ok. FYI⌠the benefit of using a custom label is it will stay in place after updating the app, if you modify the code you would need to keep replying the changes with updates.
I canât add custom field on Gross line total isnât there this option.
You can add any label if you use the âAdd Customâ option.
Was add but still no translation, is not a problem because i will edit always that texts or i can make a pull request for RO texts.php
This is still broken. Just changed and it couldnât login with my username and password.
