Version v5.10.34-M171
Environment Ubuntu 22
Checklist
Describe the bug
I see 42 Quotes in React App (Chrome Web App, Chrome Browser), but only 11 Quotes in Flutter App (macOS Desktop & iOS)
Steps To Reproduce
Expected Behavior
Additional context
Screenshots
Logs
[2024-10-11 10:35:05] production.ERROR: SQLSTATE[HY000] [2002] No such file or directory {“exception”:"[object] (PDOException(code: 2002): SQLSTATE[HY000] [2002] No such file or directory at /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php:66)
#0 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(66): PDO->__construct()
#1 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(85): Illuminate\Database\Connectors\Connector->createPdoConnection()
#2 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(48): Illuminate\Database\Connectors\Connector->tryAgainIfCausedByLostConnection()
#3 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/MySqlConnector.php(24): Illuminate\Database\Connectors\Connector->createConnection()
#4 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/ConnectionFactory.php(185): Illuminate\Database\Connectors\MySqlConnector->connect()
#5 [internal function]: Illuminate\Database\Connectors\ConnectionFactory->Illuminate\Database\Connectors\{closure}()
#6 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(1231): call_user_func()
#7 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Concerns/ManagesTransactions.php(185): Illuminate\Database\Connection->getPdo()
#8 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Concerns/ManagesTransactions.php(151): Illuminate\Database\Connection->handleBeginTransactionException()
#9 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Concerns/ManagesTransactions.php(125): Illuminate\Database\Connection->createTransaction()
#10 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Concerns/ManagesTransactions.php(24): Illuminate\Database\Connection->beginTransaction()
#11 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/DatabaseQueue.php(223): Illuminate\Database\Connection->transaction()
#12 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(350): Illuminate\Queue\DatabaseQueue->pop()
#13 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(364): Illuminate\Queue\Worker->Illuminate\Queue\{closure}()
#14 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(163): Illuminate\Queue\Worker->getNextJob()
#15 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(139): Illuminate\Queue\Worker->daemon()
#16 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(122): Illuminate\Queue\Console\WorkCommand->runWorker()
#17 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\Queue\Console\WorkCommand->handle()
#18 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Util.php(43): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#19 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(95): Illuminate\Container\Util::unwrapIfClosure()
#20 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod()
#21 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(690): Illuminate\Container\BoundMethod::call()
#22 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Console/Command.php(213): Illuminate\Container\Container->call()
#23 /usr/share/nginx/invoiceninja/vendor/symfony/console/Command/Command.php(279): Illuminate\Console\Command->execute()
#24 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Console/Command.php(182): Symfony\Component\Console\Command\Command->run()
#25 /usr/share/nginx/invoiceninja/vendor/symfony/console/Application.php(1047): Illuminate\Console\Command->run()
#26 /usr/share/nginx/invoiceninja/vendor/symfony/console/Application.php(316): Symfony\Component\Console\Application->doRunCommand()
#27 /usr/share/nginx/invoiceninja/vendor/symfony/console/Application.php(167): Symfony\Component\Console\Application->doRun()
#28 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(197): Symfony\Component\Console\Application->run()
#29 /usr/share/nginx/invoiceninja/artisan(35): Illuminate\Foundation\Console\Kernel->handle()
#30 {main}
[2024-10-11 10:35:05] production.ERROR: SQLSTATE[HY000] [2002] No such file or directory {“exception”:”[object] (PDOException(code: 2002): SQLSTATE[HY000] [2002] No such file or directory at /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php:66)
#30 {main}
