is there a possibility to add in the complete quote view the BN Number nearby to the invoice number?
because we wanne give the quote a name, that we can find it easier when we have alot of quotes in trhe system its hard to find a project
can you tell me the model controller and the view to modify?
ok found it thx
and where is the view to modify the coloumns count
i added this po_number but it wont work… normally i must edit the table for an addional td tag
$entityType == ENTITY_INVOICE ? 'invoice_number' : 'quote_number',
function ($model) use ($entityType) {
if (! Auth::user()->can('viewByOwner', [ENTITY_INVOICE, $model->user_id])) {
return $model->invoice_number.'<br>'.$model->po_number;
$str = link_to("{$entityType}s/{$model->public_id}/edit", $model->invoice_number, ['class' => Utils::getEntityRowClass($model)])->toHtml();
return $this->addNote($str, $model->private_notes);
'po_number',
function ($model) {
return Utils::fromSqlDate($model->po_number);
'client_name',
function ($model) {
if (! Auth::user()->can('viewByOwner', [ENTITY_CLIENT, $model->client_user_id])) {
return Utils::getClientDisplayName($model);
return link_to("clients/{$model->client_public_id}", Utils::getClientDisplayName($model))->toHtml();
! $this->hideClient,
January 30, 2018, 1:09am
6
can you give me a hint where i place the additional to show me the po_number?
January 30, 2018, 1:46am
9
I’m not sure I understand, you should only need to change those two files.
perfect works…
is it possible also to search in invoice items?
i added this and it works
->orWhere('invoices.po_number', 'like', '%'.$filter.'%');
what to add for search in invoice items?
thx so much
January 30, 2018, 2:59am
11
The same should work for the terms field
that does not work
->orWhere('invoices.item', 'like', '%'.$filter.'%');
also not working
->orWhere('invoices.items', 'like', '%'.$filter.'%');
January 30, 2018, 3:43am
13
Sorry, I misread. That would be more complicated.
