When I click the about button and then click on Heath Check I get the message “Queue not enabled”.
However, in the .env file the following line is there:
QUEUE_CONNECTION=database
Am I missing something?
You may need to load /update?secret= to update the config cache.
Note; if you enable the queue you’ll also need to add the queue:work cron to process the jobs.
Here’s what I have…
UPDATE_SECRET=secret
In that case you’ll want to try loading /update?secret=secret
OK, now I follow you. Doh.
I needed to put that at the end of the URI.
Now I do not get an error, in fact Queue is not even displayed so I guess that’s all OK.
I do however get this:
SnapPDF not enabled
Try changing the PDF generator in the .env file to hosted_ninja
