Hi please let me know which cron job code that Im missed to fix the Queue. The screenshot attached is my current enabled cron
You’ll need to update your .env file and set
QUEUE_CONNECTION=database
Yes it already set to QUEUE_CONNECTION=database
but still showing Queue not enabled
It may be that your cache needs to update you can use from the command line
php artisan cache:clear
or
php artisan optimze
of from a URL
/update?secret=
Hi what should o put next to secret= ?
The value for the secret is in the env file, it may be blank
The secret is not blank.
After running
php artisan optimize
The UI is non-responsive, and I can’t login anymore even in another browser.
Is /update loading for you? You can add ?clear_local=true to force a logout in the app.
It may help to test with the desktop or mobile app.
it was an issue with my browser, but after restarting it works fine. but still “Queue not enabled” is not solved yet
I have done most of the solutions but nothing work, even I tried to install the Invoice Ninja app from there also it showed Queue not enabled.
As this is really important for us to solve, we running a batch class from Salesforce to create an account and invoices (per batch 100 accounts) once invoices create it assigns to payment and once the status becomes paid it sends an email to all the customers. As we tested customers getting emails but very slowly. do you think Queue work is okay? as we getting emails. but the only issue is the time length and few customers didn’t get an email
If you changed the .env file you need to either load /update?secret= or run php artisan config:clear
I have done that too, but no luck
What value do you see set for the queue in the health check dialog?
this what i can see
v5.5.114
php version 8.1
App (mac) version 5.0.114(114)
It may help to upgrade to the latest version.
current version updated to - v5.5.117-C115
but still, Queue not enabled
I think I see the problem, it looks like you have two QUEUE_CONNECTION settings in the .env file.
Yes you are right,
I have found two QUEUE_CONNECTION, after removing one issue solved.
Thanks a Lot
Hi after enabling QUEUE_CONNECTION=database
customers not getting any email, it was working when it was QUEUE_CONNECTION=sync
(current email provide default)
any solution to fix it?
