Queue not enabled // but queue set to sync
Hi Folks,
another odd problem with dockerized IN5.
(/home/user/invoiceninja_prod/env)
I have QUEUE_CONNECTION=sync set within the env file
however, i still get this notice via built in health check feature:
any ideas?
Thank you.
The sync setting disables the queue, you can set it to database to enable it but you’ll also need to add the queue:work cron to process the jobs.
