Questions about reports
We are having some problems with reports on v5. The direct download is working fine but the “Send email” option sends the report to owner instead of the users that asked for the report. I’m not sure if it’s supposed to be like that or there is something wrong with my installation or configuration.
Also scheduled reports do not work and i have no idea why that is. They just do not run and the schedulers table does not update with new next run dates. Everything else (sending invoices and reminders) is working correctly. I have not found any documentation about how it’s technically supposed to work. Any ideas?
@david can you please advise?
@silverpark
The next release will send the report to the generating user.
I’m not sure on the scheduling issue, i’m not able to recreate this, you may want to inspect for any errors in the logs.
Thaks. The report is sending to the correct user now.
But what’s funny is that after updating today the scheduled reports also started working.
I guess all is good now. :+1:
