Hi.
Just did an update to v5.4.10-C88. Something seems to be wrong.
Variables in Purchase order details does not seem to work anymore.
Br,
Dali
Hi.
Br,
Dali
@david any thoughts?
Would the variable need to be $purchase_order.custom1 etc?
$invoice would not be available inside the purchase order
Hi.
It doesn’t seem to be looking at correct EDIT DESIGN template.
I change it to purchase_orders in edit template, but it’s the same in Purchase order preview.
Edit design template:
Purchase order preview:
Also, there is no custom fields for Purchase orders in Settings/Custom Fields.
I think the invoice designer assumes a invoice for the preview. I’m not sure we could support previewing a purchase order in the invoice designer as it would require knowing the context of the entity we wish to preview. cc @hillel
I think this would be a feature request.
@david if the backend can support it I’m happy to add the UI changes needed.
Hi.
Had a few days off. Just updated to latest version 5.5.1-C88.
It still does not pick up the right template. Something is broken.
Editing the template:
Checking in Purchase orders.
How come it shows invoice.custom1. It should be purchase_order.custom1
Thank you
Br,
Dali
As I suspected before.
Purchase order will reflect changes in Invoice Design not Purchase order Design. That explains it.
Br,
Dali
This is a bug, will be corrected in the next release.
Yes indeed
Thank you very much @david
