Hello I just upgraded from IN 5.4.8 to the latest Version 5.4.9 I’ve been having problems with Purchase Order module. I can normally add a PO as a draft but i can not sent, mark as sent or even convert it to a expense.
Is there anything i can do to fix it. Thank you
Are there any details about the 500 in storage/logs?
[2022-07-17 00:00:02] production.INFO: updating currencies [2022-07-17 06:00:02] production.INFO: Performing Autobilling 2022-07-17 06:00:02 [2022-07-17 13:17:24] production.ERROR: Undefined property: App\Services\PurchaseOrder\ApplyNumber::$invoice {“userId”:1,“exception”:"[object] (ErrorException(code: 0): Undefined property: App\Services\PurchaseOrder\ApplyNumber::$invoice at /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/ApplyNumber.php:49) [stacktrace] #0 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/ApplyNumber.php(49): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError() #1 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/PurchaseOrderService.php(44): App\Services\PurchaseOrder\ApplyNumber->run() #2 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/MarkSent.php(42): App\Services\PurchaseOrder\PurchaseOrderService->applyNumber() #3 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/PurchaseOrderService.php(87): App\Services\PurchaseOrder\MarkSent->run() #4 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/TriggeredActions.php(49): App\Services\PurchaseOrder\PurchaseOrderService->markSent() #5 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/PurchaseOrderService.php(68): App\Services\PurchaseOrder\TriggeredActions->run() #6 /usr/share/nginx/invoiceninja/app/Http/Controllers/PurchaseOrderController.php(371): App\Services\PurchaseOrder\PurchaseOrderService->triggeredActions() #7 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\PurchaseOrderController->update() #8 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction() #9 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(262): Illuminate\Routing\ControllerDispatcher->dispatch() #10 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController() #11 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(721): Illuminate\Routing\Route->run() #12 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}() #13 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(127): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #14 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(63): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest() #15 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\ThrottleRequests->handle() #16 /usr/share/nginx/invoiceninja/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #17 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\QueryLogging->handle() #18 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #19 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle() #20 /usr/share/nginx/invoiceninja/app/Http/Middleware/Locale.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #21 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Locale->handle() #22 /usr/share/nginx/invoiceninja/app/Http/Middleware/TokenAuth.php(99): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #23 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\TokenAuth->handle() #24 /usr/share/nginx/invoiceninja/app/Http/Middleware/SetDb.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #25 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\SetDb->handle() #26 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #27 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(723): Illuminate\Pipeline\Pipeline->then() #28 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(698): Illuminate\Routing\Router->runRouteWithinStack() #29 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(662): Illuminate\Routing\Router->runRoute() #30 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(651): Illuminate\Routing\Router->dispatchToRoute() #31 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\Routing\Router->dispatch() #32 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}() #33 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #34 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestIpMiddleware->handle() #35 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #36 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestMiddleware->handle() #37 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #38 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Livewire\DisableBrowserCache->handle() #39 /usr/share/nginx/invoiceninja/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #40 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Cors->handle() #41 /usr/share/nginx/invoiceninja/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #42 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle() #43 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #44 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle() #45 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle() #46 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #47 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle() #48 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle() #49 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #50 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle() #51 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #52 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle() #53 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #54 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\Pipeline\Pipeline->then() #55 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter() #56 /usr/share/nginx/invoiceninja/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle() #57 {main} “} [2022-07-17 13:17:29] production.ERROR: Undefined property: App\Services\PurchaseOrder\ApplyNumber::$invoice {“userId”:1,“exception”:”[object] (ErrorException(code: 0): Undefined property: App\Services\PurchaseOrder\ApplyNumber::$invoice at /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/ApplyNumber.php:49) [stacktrace] #0 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/ApplyNumber.php(49): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError() #1 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/PurchaseOrderService.php(44): App\Services\PurchaseOrder\ApplyNumber->run() #2 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/MarkSent.php(42): App\Services\PurchaseOrder\PurchaseOrderService->applyNumber() #3 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/PurchaseOrderService.php(87): App\Services\PurchaseOrder\MarkSent->run() #4 /usr/share/nginx/invoiceninja/app/Services/PurchaseOrder/PurchaseOrderService.php(131): App\Services\PurchaseOrder\PurchaseOrderService->markSent() #5 /usr/share/nginx/invoiceninja/app/Http/Controllers/PurchaseOrderController.php(671): App\Services\PurchaseOrder\PurchaseOrderService->expense() #6 /usr/share/nginx/invoiceninja/app/Http/Controllers/PurchaseOrderController.php(520): App\Http\Controllers\PurchaseOrderController->performAction() #7 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Collections/Traits/EnumeratesValues.php(245): App\Http\Controllers\PurchaseOrderController->App\Http\Controllers\{closure}() #8 /usr/share/nginx/invoiceninja/app/Http/Controllers/PurchaseOrderController.php(522): Illuminate\Support\Collection->each() #9 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\PurchaseOrderController->bulk() #10 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction() #11 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(262): Illuminate\Routing\ControllerDispatcher->dispatch() #12 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController() #13 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(721): Illuminate\Routing\Route->run() #14 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}() #15 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(127): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #16 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(63): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest() #17 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\ThrottleRequests->handle() #18 /usr/share/nginx/invoiceninja/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #19 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\QueryLogging->handle() #20 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #21 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle() #22 /usr/share/nginx/invoiceninja/app/Http/Middleware/Locale.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #23 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Locale->handle() #24 /usr/share/nginx/invoiceninja/app/Http/Middleware/TokenAuth.php(99): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #25 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\TokenAuth->handle() #26 /usr/share/nginx/invoiceninja/app/Http/Middleware/SetDb.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #27 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\SetDb->handle() #28 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #29 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(723): Illuminate\Pipeline\Pipeline->then() #30 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(698): Illuminate\Routing\Router->runRouteWithinStack() #31 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(662): Illuminate\Routing\Router->runRoute() #32 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(651): Illuminate\Routing\Router->dispatchToRoute() #33 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\Routing\Router->dispatch() #34 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}() #35 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #36 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestIpMiddleware->handle() #37 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #38 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestMiddleware->handle() #39 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #40 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Livewire\DisableBrowserCache->handle() #41 /usr/share/nginx/invoiceninja/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #42 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Cors->handle() #43 /usr/share/nginx/invoiceninja/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #44 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle() #45 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #46 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle() #47 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle() #48 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #49 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle() #50 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle() #51 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #52 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle() #53 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #54 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle() #55 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #56 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\Pipeline\Pipeline->then() #57 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter() #58 /usr/share/nginx/invoiceninja/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle() #59 {main} "}
@denismetko
Thanks for reporting this, it is a bug, i am checking in a fix now and will tag a new release.
Thank you David. With the new Release V5.4.10 seems all working ok.
