I don’t know if it’s just me but for any invoice designs I choose, the product-table header (Item, Description, Unit Cost, Quantity, Line Total) doesn’t show in any invoice I generate.
The header does show fine in the Invoice Designer however. I tried with all the unaltered stock designs.
It’s interesting you bring this up because I have it on “All pages”.
But the bug actually seems to be from the “Empty Columns” setting which was set to “Hide”.
After setting it to “Show”, the headers now show up.
If I set it to “Hide” again, the header gets hidden.
So probably not the intended effect I think.
But anyways, thanks for suggesting the Invoice options page or else I would have never thought of trying the “Empty Columns” setting
Check if you have something in Products tab inside of your invoice design. Content of this tab should be empty. For me, it made rows except header not appearing.
Hi @ben
May I know where can find this page?
I can’t find in Invoice Desgin.
when my invoices are more than 1 page, the header and footer are not repeated.
Please help
