Can you add a field for the item cost as well as a markup field and have the price field populated based on that calculation. It’s nice to know if an item had a price change and to keep your markup consistent with revised pricing.
April 25, 2024, 2:32pm
I believe this request is being tracked here:
opened 08:01PM - 10 Apr 23 UTC
feature request
**What version of Invoice Ninja are you running? v5**
**What environment are… you running?**
Shared Hosting
**Have you searched existing issues/requests?**
**Screenshots**
![image](https://user-images.githubusercontent.com/91687578/230987492-e9c83bdb-c38d-4ec4-b6a2-a308040c6b02.png)
**Additional context**
In Quickbooks quote/estimate section, I have the ability to add a “margin” column so that I can add in the percentage or number that I will “uplift” items that I’m selling. This adds a visual or at-a-glance view as to how I work each deal. The quote PDF does not show the actual margin gained only the cost, quantity and total so basically the customer does not see the margin. Is there a way to add this to InvoiceNinja to work similarly or would this be a code change/suggestion?
