Product Descriptions
Hi
Is there a way to stop the description being updated on the ‘Products’ you create? For example I sell hosting and domain names so I select a particular TLD e.g. ‘.com Domains’ and the description and price is added to the invoice. But I then add their particular domain name to the invoice and this in turn is being added to the ‘Products’ description which is a bit of a disaster. Can this be turned off?
Will
You can disable the “Update products” options in the product settings.
